dlhancock's avatar
dlhancock
Blowouts!!!!!!! Tires????
We are running Power King/Tow Max tires on our 33 ft. KZ 5th wheel toy hauler. It has duel axles. We bought our trailer new in 2006. The GVWR on the trailer is 13600 lbs. Actual weight of the trailer is 9170 lbs.
When we load it with our Harley Tri-Glide, water, propane, food and clothes, we figure we are at about 12000 lbs.
We always run at 80 psi, and have an electronic monitor on the tires to keep an eye on them going down the road.
The reason I'm writing is, we have had many blowouts on this trailer and don't know what to do. We had the axles changed in 2010 from 6000 lbs. to 7000 lbs. because they were bent and now they are straight and in alignment. The dealer (who is no longer in business) suggested not putting 80 psi in the tires which is stamped on the tires. We knew that was wrong.
The tire size we are running is: ST235/80R16 10 ply
This tire is stamped, for duals 3080 lbs per tire. Just had another blowout. Only thing we can figure is the tires can't take the weight.
Has anyone else come across this problem and what did you do to fix it? We were wondering if a 14 ply tire would solve the problem, if the tires would fit or if this would create a new problem.
  • First off...welcome to the Forum.
    Questions to help clarify your situation:
    • Are the tires that are failing the original tires...2006?
    • How fast do you normally drive?
  • Cheap chinese tires upgrade to LT tires and be done with your problems, if you have 7000 pound axles up grade to 17.5 inch tires.
