Sirheho's avatar
Sirheho
Blue and red hose
I own a Rampage toyhauler . My hauler had two hoses on the side of the sewer lines . Anyhow , when I try to turn on my faucet(pump on ) water flows outside of my hauler . I have never had this issue before . Did I accidentally open a valve ? Where would this valve be located ? I can't even flush the toilet and obviously take a shower . The hoses on the outside show no signs of a valve anywhere underneath the carriage . Any help would be appreciated . Thank you
  • If you never winterize in LA, I would guess that some kids were pranking you at a campground or a neighbor lost his caps.
    bumpy
  • Thank you everyone. I bought some caps for now . It is working . I will check for valves once I return from vacation
  • We had a TT that had the low point drain valves hidden under the shower. There was a panel that had to be removed and then they were hiding in the floor.
  • Blue (cold water) & Red (hot water) lines are your 'Low Point' drains
    Not familiar with YOUR TH.....
    but some low point drains have screw on caps, some have plugs that you pull/push to open/close and some have shut off valves.
    Visualize where the lines might be inside based on where they go up thru underside.
    Check for any shut off devices.....basement compartment, side compartment, wet bay compartment etc.
