RazorKQ's avatar
RazorKQ
Bolts in floor
IT looks like I have some bolts starting to come up from the floor (bumps in the flooring). What is the best way to access them? Would I remove the flooring on top or remove the insulation from underneath? I want to choose the correct path as to not cause me any issues. Thanks
  • Thanks folks. I will pull the flooring and see what I can do. The problem is I have one coming through the vinyl flooring up front also. I probably can't cut around that one. Thanks for the responses and I am glad someone else has/had the exact same issue and opened it up to see what the cause was. Thanks again.
  • I've had the same problem for about 5 years now and unfortunately these are large self tapping screws that backing out if the frame. This is how they chose to secure the floor to the frame.
    I originally cut the vinyl flooring in an L shape, removed the screw, filled the hole with liquid nails, reset the screw and then used a vinyl seam seal kit to close up the vinyl. I did this for the first 3 I found but the seam seal does not hold well. Probably operator error :(. Now I just cut a hole in the vinyl the size of the screw head, complete the usual process and seal the hole with a countersunk washer to keep the flooring in place. I have 6 or 7 like this with 3 or 4 more that will be addressed this year. On the bright side, at this rate I will have done them all by next year!:R All I can say is thank god for carpeting, it hides everything.
    I thought is was just my Rage'n that had this problem but I'm hearing more about it sad to say.
  • Y-Guy wrote:
    That's very odd. I think you're better of starting below, see if you can tighten the nut (assuming it's below at least) you could hold the bolt from below too, depending on how much room there is. Might add a nylock nut underneath too so it doesn't back out again.
    +1
  • That's very odd. I think you're better of starting below, see if you can tighten the nut (assuming it's below at least) you could hold the bolt from below too, depending on how much room there is. Might add a nylock nut underneath too so it doesn't back out again.
