SoundGuy
Jul 03, 2015Explorer
Bmach wrote:
I have never traveled with anything in my tanks, except a couple of gallons of water in the black tank.
That's unfortunate as that then means you're not able to take advantage of one of the great advantages offered by owning a trailer you can get into by simply opening the door - using the facilities, anywhere, anytime. It also means that when you do want to use the system you first have to re-pressurize it ... can't imagine going through that when I can simply do it once at the beginning of the season. :h
As for the grey and black tanks I usually do travel with an empty GW tank but the BW tank could have any amount in it because I never waste my time at campground dump stations as I'm set up to service my tanks at home using my FloJet Waste Macerator Pump. I only do this of course because I've carefully inspected the grey and black tanks (easy to do with an open underbelly) and have no concerns at all that either would ever fall off the trailer, empty or full.
About Fifth Wheel Group
