Halmfamily's avatar
Halmfamily
Boom goes my fresh water tank....
Leaving on Wednesday for a five day trip, filled fresh water tank half full per tank indicator so we can start preparing and boom the water tanks holding brackets bent and the tank fell out. Wow that was a loud noise, shook the fiver and my son heard it from inside the house.
Pulled back the coroplast and both the fore and aft L brackets were bent downwards. I drained the tank and put a ratchet strap under it to keep it in place. Forest River will get a call first thing in the morning to see what they can do, still under warranty. if push comes to shove I'll remove the aft bracket and remove tank so we can still take our trip.
I'm just glad this didn't happen while pulling it down the interstate. Sorry,, just had to vent. I'd post pictures but only have a tablet.
Happy Fourth everyone.
  • Sorry to hear that. I can only imagine what a mess it would have been going down the highway with it grinding along!
    But it sucks that it happened right before a trip.
    Good luck and let us know how they handle it.
    Scott
  • Sounds like their intention was to put as little steel under the tank as possible, and hope that it fails after the warranty expired. Good for the repair business - I guess?
    I would want a flat bar strap between both of the 'L' brackets that seem to be all that is holding it now. . .. This way the L bracket will not pull away from the tank, and anything under the tank is better then nothing under the tank.
    You can buy 1" wide and 2" wide aluminum flat stock from Home Depot. If there is space to put a bolt into the L bracket without it touching the tank, it will work, and then have the strap under the tank, fore to aft. Perhaps even two straps? I probably would be buying 1/8" thick 2" wide straps.
    Good luck,
    Fred.
  • Sorry to hear that. This******pisses me off. Things like that should not fail. There is no electronics or motors involved. Its piss poor engineering that should of been done right the first time.
