D_E_Bishop
Apr 13, 2015Explorer
d-mac1 wrote:
Genny is fine. There is an issue with transfer switch. There are 2 switches in the housing. When I started genny, an led lit up on the one with only 1 set of real heavy gauge wires coning into it. No output from either switch. With meter connected to switch output lines, if I manually depress the switch with the led, I hear converter fan run and have ac power. Switch is PD52. The output of switch I'm operating by hand goes into lower connectors on other switch which I'm assuming is for shore power.
Can I just replace one switch or need to do entire unit...or is something else the problem?
Thanks guys. All comments are helping!!
Here is a downloadable PDF of the switch. Included is a trouble shooting guide.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
