CarnationSailor
Feb 15, 2021Nomad
MFL wrote:
Brake wires shorting inside your axle can cause this. The wires chafe over time and short out in the axle tube. It can cause an intermittent problem, due to bouncing wires inside.
Jerry
X2
had similar problem due to wire rubbing on brake drum. Rubbed thru insulation and caused intermittent max application of brakes.
About Fifth Wheel Group
