lenr
Feb 17, 2021Explorer III
Increasing wire size along with rewiring everything has helped me on three different trailers. I use 12/2 with one run to each axle--that is even larger than using one 10/2. The more wire capacity to the hubs, the less voltage lost in the wire. Rewiring also helps eliminate broken connections.
About Fifth Wheel Group
