ElwoodjExplorerJun 07, 2015Brake Drum ScrapingA passing motorist said that he heard or thought he heard the brake drums scraping on our fifth wheel. These are never lube axles is this possible , if so what is the solution?
Old-BiscuitExplorer IIIJun 07, 2015Well........You need to jack up wheel one at a time and sin wheel listen for sounds with and without brakes being applied.Then you probably need to manually adjust brakes due to worn shoesAnd you may even have to pull drums and inspect internals
Related ContentTurning Brake DrumsReplacing drum brakes ???P30 Disc brake vs drum brake ball jointsHow difficult to install new brake drumsScraped my Bumper!
