Elwoodj
Jun 07, 2015Explorer
Brake Drum Scraping
A passing motorist said that he heard or thought he heard the brake drums scraping on our fifth wheel. These are never lube axles is this possible , if so what is the solution?
othertonka wrote:
Could be the Magnets rubbing on the drum rotor like they are designed to do. The magnets have a spring behind them to keep them positioned properly so when you apply the brakes, the electric magnets get energized, grab onto the drum rotor and apply the brakes. jack up the wheels one at a time and spin the wheel and listen. if you hear noising, just pull the drum and take a look. Visual inspection is about the only way to tell.
