A passing motorist said that he heard or thought he heard the brake drums scraping on our fifth wheel. These are never lube axles is this possible , if so what is the solution?
I took the fifth wheel to Campers Inn of Atlanta. Technician removed the tires and cap, had never lube axles so had to remove clip, torque nut and never lube hub. All brake pads are ok. The front off door side magnet was missing clip to hold on magnet. In stalled new clip. They tested all brakes and adjusted, tested ok. Now I am $460.00 lighter, but I have peace of mind.
