joebedford wrote:
Edd505 wrote:
joebedford wrote:
I hook the TH to my TV and pull the break away - wheels don't turn then. Easier than jacking the TH up.
Won't identify a one wheel brake not functioning.
That's not the function of the breakaway switch. I check wheels individually for braking function when I adjust them - all the way from the brake controller in the truck not halfway from the breakaway switch.
The function of the brake away is to lock all brakes upon a hitch failure. Pulling it shows me it's working & on each wheel, no bad magnets or broken poor connected wires.
And you individually check each wheel how when adjusting? And how from the brake controller? SO which way is it??
