JRscooby wrote:
Learjet wrote:
Clamp on DC amp meter would be a better test.
I have seen LEO use the compass to check brakes in a roadside safety check. To tell you anything you need to hold compass near hub, but not so close that needed responds to the metal, apply brake, watch for needle to respond. The most it can tell you is there is power to magnet(s)
Yes, the AMP meter would be better, but bet a larger percentage of people have a compass.
dougrainer wrote:
ALL the Breakaway switch does when activated is put FULL 12 volts to the Trailer brakes. AS long as you have a GOOD Trailer battery. An easy test is to simply connect the Trailer to your Truck. PULL the Break away lanyard loose
BAD ADVISE! Unless you tell them to disconnect the light cord. There is a chance the brake controller will be damaged by power back-feeding if the pin is pulled while connected
and then attempt to drive forward(NO truck brakes at all). Have someone WATCH all 4 wheels and tires ALL should be locked up and drag. It is best to do this on dirt or gravel lot. Concrete will not be a real problem for this test, but it is easier to drag on Dirt or Gravel. This will tell you that the Shoes and magnets are in working order. If you have a Wheel not locking up you then test the 2 wires going to that Brake and see if you have Ground and 12 volts. If NOT, then find where the open circuit is by the axles. If you DO have 12 volts then the Brake shoes are probably not adjusted correctly. Doug
I have never in 42 years had a Back feed. BUT you are correct. To do the test with more safety, disconnect the 7 way plug and then pull the lanyard. Doug
