bucky wrote:
bgum wrote:
We usually run on 3-4 with prodigy p3. Boost set at 1-2. You may be running a little too high. Is your 5th wheel pushing the truck when braking?
The trailer would not be pushing the tow vehicle in this scenario. It would be the opposite.
As to pulling the safety switch and worrying about the controller just get somebody to push the brake pedal for you while hooked up.
It appears you misunderstood my underlying question as to why he has his brake controller set that high. Does/Did he feel that way and therefore set it high.
