Just replaced my orginial battery with a brand new one two days ago. We are at the campground now and it is dead... wondering where do I start to look before I run out to get another one...,,
I bought two new Interstate batteries this Spring and they would not hold a charge. Took them back, and after much testing, they swapped them for two good ones. No problems since.
Yes, you should have a multimeter. If you watch the sales you can get one for free at Harbor Freight. They're not the greatest but it will do the job.
And, just because you have a new battery, it doesn't mean it's not bad. I've bought things, including two new car batteries, that were bad. That's probably not the case but, it can happen.
Get out your voltmeter and check if the converter has 120vac in and 13.6vdc out. If you can get your hands on a 10+ amp portable charger and put it direct on the battery it will buy some time while you sort all this out.
If you have a battery disconnect, make sure it's ON. I learned the hard way that, even if plugged in, if the disconnect is OFF, my batteries won't charge.
If all is connected properly your 12VDC battery terminals should read 12.6-7VDC when fully charged. Not having an inexpensive multimeter is no excuse. They only cost $7 to $20 from LOWES-WALMART-AMAZOn, and many auto parts stores. Northern TOOLS used to give you one for FREE with purchases back in the day. Don't know if they still do that now or not...
Without shore power ON you should be able to turn ON your trailer ceiling lights which will run from your connected battery.
When you are connected to shore power you should be able to read 13.6VDC at your battery terminals indicating your on-board converter/charger, all connections, in-line fuse, REVERSE POLARITY Fuses, are working normal.
Check to make sure you have the battery connected proper before replacing any blown fuses otherwise they will just blow again. Find the word 'NEG' or symbol '-' on the battery case and make sure the battery cable coming from the trailer frame ground is going to that terminal. Some new batteries from the same manufacturer will have their terminals on the other side of the battery and you can get them hooked up wrong for this reason. Check for the Battery Terminal ID marking first...
These are things I always look for the moment I make changes. No way will I just throw in a new battery and head for the mountains haha...
Not fun showing up with dead battery all of a sudden...
If you are plugged in to CG power, your onboard charging system should be charging. If not, you can get a charger to hook up direct to the battery, to get by, until your onboard system is repaired/replaced.
Sounds like the converter is not charging the battery. Use a volt meter to test the voltage at the battery. If your on board charging system is working correctly, it should read at least 13.4 volts. If not, you have a problem with the converter. Good luck.
