wanderingaimles
Mar 08, 2019Explorer
Having just wintered in a Rockwood, even though you didn't identify where, should have given you a good idea of what to look for.
If your in an area with nighttime lows around freezing, something like your Rockwood can manage. Enclosed underbelly, heated tank pads, will make it tolerable. As your lows go cooler so does the difficulty. Dual pane windows, additional insulation packages, underpinning or skirting all can help. Most folks take advantage of the portability and just move to suitable climes.
If the fit and finish of the Rockwood are in line with your desires, look at the Cougar and Montana high country lines from Keystone. They dont void a warranty for full timing. Neither does K-Z or Palomino.
Others are available in all the manufacturers lines, find a floorplan you like, then start perusing brands and manufacturers, they all basically make similar designs in their individual product lines.
About Fifth Wheel Group
