djgarcia wrote:
BarneyS wrote:
Those switches are quite inexpensive and easily replaceable by just about anybody. If however you are unable to do so, I would just disconnect the battery and tow the vehicle to the repair shop. By doing that the emergency breakaway will not be functionable so drive very carefully.
May not be legal but that is what I would do - depending on how far away the repair shop was and whether travel on high speed highways was necessary.
Barney
Would that be the same as using the "battery switch" knob and just turning it off like you do when you put the 5th wheel into storage for the winter??
Probably not. That battery disconnect switch is usually for the house batteries but the breakaway is most likely wired directly to the battery and would not be affected by that switch.
I guess it kind of depends on how the switch is wired. You should be able to take a look and see where the breakaway wire goes.
Barney
