Njmurvin's avatar
Njmurvin
Brighter porch light
I have one of the standard oval shaped porch (door entry) lights. I just switched out the bulb for an LED and my wife is complaining that it isn't bright enough. I was given the bulb so I don't know the wattage - but it may be as bright as it gets for an LED for this type of bulb (automotive brake light style socket). The fixture isn't in great shape so I thought about upgrading it to something with two bulbs or just something brighter. Any suggestions?
  • I mentioned Greg being in Q after looking at your location (reasonably close). As mentioned, Greg will be out there with all his products I'm sure.
  • I've replaced the scare bulbs with LEDs from Super Bright LEDS ( https://www.superbrightleds.com/cat/rv-led-lights/?view=standard ). They probably aren't the cheapest but what they do give you is a list of bulbs with a description of the lumens, color temperature, direction of beam angle and quantity of actual LED bulbs in the array. I ended up with 360 lumens with a clear 6200K color. These have a bit too blue light for me, but they will stay. Gotta say that if these were meant to 'scare' someone, they will. The tail/brake light bulbs have been converted as well and are bright vs the poor light output originally supplied with the 2057's
    A note about buying LEDs - you need to purchase the same color LED as the lens - and many porch lights are amber while tail/brake lights are red - and need the proper color for proper light transmittal.
  • Personally I do not like the way the typical porch light directs light, I understand the reason for the designs and how difficult it is to design a fixture that shines down and does not stick out horrifically. We don't sit out very late and so lighting up our whole "patio area" is not important to us. When the campfire goes out we go in.
    We want light when we approach the door that illuminates the steps and area around the steps. On our last rig I installed a 12", waterproof strip of amber LEDs under the bottom of the door threshold that illuminates the top step, that was controlled by a little 12volt remote switch or relay.
    Today the remote switches come in a very large variety of functions and control up to ten or so on-off relays and amber LED strips are enclosed in plastic fixtures. There are also several approach sensors available that can be used to do a variety of things.
    I like to tinker and don't like bright lights while camping so it works for me, some folks sit outside a lot more than we do and want patio lighting, there are more and more configurations of LED strip fixtures and approach sensors and remote controllers. We have the typical Tri-Mark entry handle and I hate not having a light to illuminate the key slots, gotta work on something for that so it illuminates the slot but doesn't shine in my eyes and looks like it is part of the door lock.
