AMG1978's avatar
AMG1978
Broken floor plate for tubes holding table
I have a 2016 Forest River Stealth toy hauler. It has these floor plates with holes. I put the chrome poles in and put the table on top. I see the floor plate broke. Any idea where I can get a replacement? No idea who makes this....
Picture here https://goo.gl/photos/qtZ2Yw1uE5HBYFvb9
  • Yes they are cheap and easy to find on-line. They are really easy to break. My wife lightly leaned on a table and broke the base.
    And as a side note: At the time she was 7 months pregnant and I told her it was fine and she could break anything thing in the trailer she felt needed breakin.
  • nayther wrote:
    common part, there are two versions, one is recessed, like in the pic. the other is surface mounted, kind of a teepee. Most likely caused by leaving the table up when you travel, it rocks back and forth and these are only pot metal.
    Thanks to the IAMICHABOD on that, I used the PN and found it on Amazon Prime. I got 2 just so I had 1 extra, and saved a little on shipping.
    Yes, the one like a teepee is on the underside of the table.
    Thanks a lot folks.
  • common part, there are two versions, one is recessed, like in the pic. the other is surface mounted, kind of a teepee. Most likely caused by leaving the table up when you travel, it rocks back and forth and these are only pot metal.
  • take the old one out and go around to various RV dealer's. should be a common item. also marine is a possibility but check the size.
    bumpy
  • I have a 2012 pacific coach works powerlite and I broke a 2 of the stock ones, just did a Google search and ordered new ones somewhere online haven't broke them yet.
  • A 2016 with a defective floor sounds like Forest River needs to install a stronger floor that can handle the table mounts?? Is broken floor caused by inferior materials like 1/8" cheap plywood?
