TimnJo's avatar
TimnJo
Broken Leaf Spring
Discovered a broken spring pack when we arrived at the campground. Called a local RV place and obtained a replacement. Now, to replace it my BIL thought we could pull the other wheel up on a ramp he has and with one of my two bottle jacks we could work the broken one off for replacement.
I would rather jack the frame up on that side and, with the wheel removed, replace it.
We're both mechanically inclined and have the tools necessary, including lots of 2X12, 4X4 and 6X6 wood to crib the frame up.
What are your thoughts as to the best method?
TIA.
P.S. just wish I had brought my impact gun and power ratchet!
  • You may also want something like a floor jack under that axle so it doesn't fall and slam down because of the weight on the axles on the other side of the rig.
  • You want both axles hanging from the frame on that side as a minimum.
    Yes jack the frame and build the cribbing for support while you work.
  • rhagfo's avatar
    rhagfo
    Explorer III
    rjxj wrote:
    I agree, try to support the frame in front and back of the wheels so there isnt weight on the opposite axle. Break the lugs loose, jack under the axle close to the wheel and get it off, then lower the jack slowly and find the spot where it loosens up. There will be a point where the pressure is off the bolts. You want the system sort of floating with no real load on the other axle.
    X2!
  • I agree, try to support the frame in front and back of the wheels so there isnt weight on the opposite axle. Break the lugs loose, jack under the axle close to the wheel and get it off, then lower the jack slowly and find the spot where it loosens up. There will be a point where the pressure is off the bolts. You want the system sort of floating with no real load on the other axle.
