grampscamper
Oct 01, 2016Explorer
MFL wrote:
Sorry to hear of your damage! I think most any slider, used in the puck system is going to make your FW a little high in the front. IMO, an inch or two nose-high is not a problem.
I am curious as to how far back your pin is from the cab? I know circumstances can change quickly, such as a down hill. Were you making a forward U-turn? I have towed many years with my pin 40.5 inches behind cab, and last several years at 40 inches back.
What hitch are you using now? Some standard hitches have good adjustment ahead/back. The center of your 2013 Ford axle should be at 41 inches.
Hope you find a workable solution!
Jerry
I was doing a U turn in a parking lot. I have a Husky fixed hitch. I'm not sure the distance from the cab but I will measure. My hitch doesn't have any front to rear adjustment.
Thanks
Bob
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
