In more than 30 yards of rv’ing, we’ve experienced 3 broken springs.....two in the last 3 years. Two of these were on while on the road. The most recent, discovered when making my “walk-around” while doing an afternoon refueling at a truck stop 50+ miles south of Lincoln, Ne. We spent the night in the truck stop while a cold front pushed-through, setting a low temperature record in Lincoln. The next morning we drove into Lincoln (after getting permission to leave the 5er in the lot), and bought 2 springs. I replaced the spring (it was cold work)and we were back on the road by 10:00or so. The second spring has found a semi-permanent home residing in the bed of our truck. We should “never” break another.....as we are now prepared.
It seems that our repairs always happen during somewhat “extreme” temps. :M The previous spring change was done in an asphalt parking lot in Mesa, Az.....in August! I did that repair in early morning, while it was a little cooler....but rapidly getting hot. I was very thankful for the large piece of “Astro-turf”, I keep for putting on tire chains ( mud or snow), which helped “insulate” me from the hot asphalt!
And then, there was that wheel bearing / brake assembly replacement during the Christmas Holidays, several years ago. Done in a campground, with morning temperatures below 0F. That required more than one cup of “hot chocolate”!
Rv’’ing can certainly be an adventure ! We should write a book! memtb
