voodoo101
Aug 27, 2019Explorer
broken springs
I discovered a broken spring on my fiver about 5 years ago. Considered it an anomaly and replaced it. This summer I discovered another spring broken while on the road in Utah. Stopped at a Flying J in Scipio to get it replaced and found two were broken, one on each side. The second probably happened on the crappy section of IH-15 south out of Salt Lake while I was looking for a repair shop.
Anyway, getting to the point I had all 4 replaced with heavier 5 leaf springs vs 4 leaf that came on it. Sunnybrook made excellent trailers in that time frame but like all manufacturers they used only the minimum required. The OEM tires were D rated (just barely enough) and I upgraded to E. I am sure the springs were adequate, but probably just adequate. Something to consider if one is having suspension work done. FWIW
