Thurbersfolks's avatar
Jun 19, 2013
Broken Wheels
I just finished a 8000 mile road trip around the US. Broke all of the original wheels at the weld on the rim to lug center. I was running 6 lug 15" wheels and weighed in at 10400 lbs. which was the max on the wheels. Each was stamped 2600 lbs. I was able to go to an 8 lug hub on the same axle. I checked with the Company, AL-CO, and they said that would be fine if total trailer weight did not exceed GVW on the tag. After changing out to bigger , heavier wheels, drums, tires everything now is fine. I feel Forest River undersized the wheels. Trailer just a year old. Who gets the bill? I do because knowone will except responsibility.
  • Raceline makes heavier rated aluminum rims in a 15" diameter 6-lug which can be purchased at Les Schwab locally. This is a good option if your tires do not need to be replaced. My Weekend Warrior ran dual 5600 lb axles and started showing signs of fatigue in the OEM rim's cutout pattern less than a year after I replaced all the original tires due to wear. It was typically carrying close 11,000 lbs on the axles when we were fully loaded with water, supplies and toys.
  • Thanks for the input. I have a BP Sandstorm 28' Forest River toyhauler. Great trailer too, and not as much wear on the 16" tires and wheels either. Wore a set of the 15" tires out in less than 10,000 miles.
  • I broke 3 steel wheels on My Thor Wanderer, 2 originals and one replacement.
    2 at the welds and one at the bead area. Just like tires, they put the cheapest junk they can get on these rigs. The steel 16" wheels on there now are rated @ 3,500 #'s each.
