I should add, if its a halogen type bulb, those can burn out (and even explode!) if you get oils from your skin on them, some bulb/fixture manufacturers go as far as including a cotton glove, or a gripping tool to change the bulb. I only add this because I know there are some 12v halogen type bulbs on some rigs, however I don't know if this applies or not here.
Directly from wikipedia:
Handling precautions
Any surface contamination, notably the oil from human fingertips, can damage the quartz envelope when it is heated. Contaminants will create a hot spot on the bulb surface when the lamp is turned on. This extreme, localized heat causes the quartz to change from its vitreous form into a weaker, crystalline form that leaks gas. This weakening may also cause the bulb to form a bubble, weakening it and leading to its explosion. Consequently, manufacturers recommend that quartz lamps should be handled without touching the clear quartz, either by using a clean paper towel or carefully holding the porcelain base. If the quartz is contaminated in any way, it must be thoroughly cleaned with denatured alcohol and dried before use.
