We're going to pick up a used open range fifth wheel on Saturday. It's a 2014, and was purchased as guest room, never been on the road since delivery. The owner says that tires look perfect, no dr...
Don't get hung up on metal valve stems as djgarcia suggests. However, do get valve stems rated for the tire pressure you intend to use on the tires. There are very serviceable non-metal valve stems that will handle 110lbs. plus.
