NJRVer
Nov 03, 2013Explorer
I would go for it as long as the rot is confined to the walls. If it hits the floor then you have to remove the wall studs off the floor to fix the floor since the walls are set on top of the floor.
Otherwise remove the rotted paneling and replace the insulation if it is messed up, spray to kill any mold spores.
About Fifth Wheel Group
