Durb wrote:
You can use an 18k Patriot with standard bed rails. I cut out rectangles in my BedRug to fit tightly around the rails. This works particularly well with the thick BedRug as stuff like lumber just slides over the rails when loading. Almost like a flat floor; I said almost.
Congratulations on the new trailer.
Thank You. I'm really looking forward to it. The Companion has most of the hard mounts on the chassis rather then in the bed. The strong point is through a single hole in the middle of the bed, so when you take the hitch out, there are no rails in the bed. I will get some extra velcro and just replace the large square back in place when the hitch is not in the bed.
