laknox wrote:
I found a 2-ton engine hoist on sale for $99 a number of years ago and use that to lift my Companion in and out of my truck in one piece. Just loosen up the hold-down and u-bolts, pull the pin, and it comes right out. I =did= have to lengthen the boom a bit to reach the center of the pin. Made a small chain with a plate on it to go in the jaws. Got a 1,000 lb furniture dolly at a Harbor Freight a couple miles from me for $10 and set the hitch down on that to roll around the garage. I figure it paid for itself with many fewer trips to the chiropractor. :-)
Lyle
Can you post a pic of the engine hoist modification?
Also what size plate did you guys use?
Thickness and side to side. I thinking 4x4x 1/2?
Also how much do you loosen the hold down bolt? Do you grease the pin to make it slide easier?
