garyp4951
Mar 09, 2014Explorer III
oilslick wrote:
I have a 20 X20 full width toolbox with a companion in a ram SB. I have the toolbox raised 2 inches on 2 pieces of aluminum square tube at both sides, this gives the option of loading plywood or studs down the center. To get the hitch in and out I cut the tool box lower rear corner at 16 inches from the front then again at 5 1/2 inches from the bottom. To cut the aluminum toolbox just use a circular saw with a very fine carbide tipped blade, works well and does not damage the blade.. I then inverted the piece I cut out and reinstalled it into the toolbox. My original plan was to weld the piece back in but it was too small because of the blade cut so I used 2 pieces of angle aluminum extrusion with construction adhesive PL Pro and pop rivets. I then painted the whole toolbox to match the truck. With the toolbox raised 2 inches it gives 7 1/2 inches of lift upward to clear the B&W.
That is a great idea, and I won't have to spend another $300.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
