driver75
May 08, 2013Explorer
B&W hitch
I am considering buying a B&W patriot fifth wheel hitch and when it comes time to remove it from the truck bed can it be lifted by one person.
webslave wrote:
I am in my 60's, have rheumatoid and osteoarthritis along with a slipped disk at L2-L3, and I take my Companion out "solo". So, yes, it can be a "one many job". I do have a hoist (for other things) and I have an electric winch mounted to the ceiling in another workshop area, but, I just back the truck to the garage door, seperate the head, place it on the tailgate, disconnect the base and put it on the tailgate, get out of the bed of the truck and put the base on the floor next to the door (up on blocks) and then replace the head on it. It sits there that way until I need it again and then I reverse the procedure. Would be too much if it were all one piece, and even seperated, the base is heavy, but, still manageable. If I'm having a "bad day", the DW helps get the base up onto the tailgate, but, she is only 5' and has a hard time lifting things that high, so I tend to do it myself. So, yes, one person can get one out and back in; help with almost anything, though, is always appreciated if available, but, if help isn't available, you aren't stuck. If you do need a lift or hoist, even for a B&W, you'd still need one for virtually any other hitch made...most don't come apart so you're stuck with the deadweight of a single piece. A B&W is probably your best bet for not needing a lifting device to remove it.
Before anyone chimes in; I am retired and have no desire to work for or involve myself with any company, but, like Cummins12V98, I think they (B&W) are probably, dollar for dollar, the best hitch out there and I don't mind saying so, either. While the B&W is "just a hitch", like anything else, you have various stages of "quality" in that category and like many other B&W owners, we think the B&W stands at the top of that stack based on form, build quality, features, ease of use and company support of the product.
fj12ryder wrote:
I don't know about the Patriot but I believe they use the same head as the Companion. The Companion is an excellent hitch and you'll never have to worry about dropping your 5th wheel with one of those. ;)
Cummins12V98 wrote:alageezer wrote:
I also highly recommend the Patriot, and the purchase from Tweetys. I'm 66 and disabled, but could manage the head fine, the base with some effort.
I just wish people would at least check them out and compare to the others.
I can't stand the clunk that you get with some of the other hitches.
