mtofell1 wrote:
I'm currently running a B/W slider in my 2014 Ram that came with the single hole in the middle of the bed. I see in looking at 2016 models that things have changed and now there are 4 holes spread out in the bed. What are the options to make my hitch work with one of these newer trucks?
Your 2014 has the B&W after market turnover ball gooseneck installed. As pointed out if you now are going to a long bed you can just get the B&W RVK3600 base. If you still want to use your B&W slider, then remove the B&W turnover ball setup, as your hitch will not work with RAM gooseneck ball.
Chris
