I don't know if you have a hitch already, or can borrow one if you already have the rails. I Meashured my trailers width and divided it in half. Then Meashure from the back window to the center of where the hitch would be in tow mode. If it is a lot less than the width of your trailer divided in half then I would get a slider.
Example. My trailer is 97" wide in front. Half that is 48.5". The meashurement between my aluminum back rack and the center of my hitch in fwd position is 36.5" So I bought a slider. I also opted for the Reese round tube as it had 12" of travel as opposed to the square tube 10"
For a rough estimate, you can judge just about where the center of your rear axle is under the bed of your truck, then go 1" inch or so in front of center towards the cab for your reference point. Most hitches run centered over the axle or just in front of it.
Good luck.
