Charlie_D_
Jan 25, 2014Explorer
Cummins12V98 wrote:Charlie D. wrote:
After 9+ years, I think the glue has failed. Following suggestions of the first 2 respondents and you should be good. I have gotten to where I use Gorilla glue for most of my projects.
That stuff is******use a quality wood glue like Tightbond. As said liberally apply and with a damp cloth clean off all excess glue.
You would never see a cabinet shop use Gorilla Glue.
Are you sure a cabinet shop would NEVER use Gorilla glue? Titebond is a good glue and would work but it does not take care of any looseness if that is part of the problem. Gorilla glue will help fill any gaps and is superior for those purposes. Wiping with a wet cloth will remove most of the excess and a sharp chisel will remove any hardened excess.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 11, 2026
