Charlie_D_
Jan 25, 2014Explorer
Cummins12V98 wrote:Charlie D. wrote:Cummins12V98 wrote:Charlie D. wrote:
After 9+ years, I think the glue has failed. Following suggestions of the first 2 respondents and you should be good. I have gotten to where I use Gorilla glue for most of my projects.
That stuff is******use a quality wood glue like Tightbond. As said liberally apply and with a damp cloth clean off all excess glue.
You would never see a cabinet shop use Gorilla Glue.
Are you sure a cabinet shop would NEVER use Gorilla glue? Titebond is a good glue and would work but it does not take care of any looseness if that is part of the problem. Gorilla glue will help fill any gaps and is superior for those purposes. Wiping with a wet cloth will remove most of the excess and a sharp chisel will remove any hardened excess.
I don't want the glue to "fill" the gaps. I want it to bond. Chizel on a finished product?
Should not say never but any of them I have worked with would not use it.
I have seen the mess Gorilla Glue leaves, it keeps growing until it dries. If you don't care about how the job looks…..
35 years as a Finish carpenter/Construction Superintendent.
I find that an excessively loose joint doesn't hold as well as a tight joint and that looseness sometimes causes another failure. A glue with expanding properties will bond and often solves this problem. I've used Gorilla glue many times, being careful with the amount and not had the issues you speak of.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
