- MC9ExplorerI cut a slit from the bottom up in the plastic insert (so it can flare a little more) slather everything with Elmers and put it together wet. Don't you just love those "European" hinges?
- goducks10ExplorerHad the same issues with our last TT. I put some Super Glue on the plastic insert, pushed it back in then re-screwed the hinge. After doing that they never loosened up again.
- D_E_BishopExplorer
MrRetired821 wrote:
Had same thing happen to a cabinet door strut. I got a wooden dowel that fit the hole where the plastic one was and cut it flush with opening. Used wood glue to secure the dowel in the hole. Screwed the screw into the wooden dowel and so far no problems.
This is a great idea and as was said earlier, times changes and new ideas come foreword. I am a sawdust maker(home woodworker) and I found that using my dull pencil sharpener to sharpen dowels like a pencil, but to a very dull point, the pointed end about 1/8" diameter, makes a really good plug for a stripped out screw. There are tapered reams available that are very close to the angle of a sharpened pencil.
I use a sharpener with dull cutters because of the whiskers created on the taper. They increase the area that glue adheres to and provides more glue deep in the hole.
I have been using this system for years and in most instances no hole needs to be drilled in your face frame or other work. Just reaming out the screw hole will work well.
I know it is another expense and lord knows our lifestyle requires buying many things but this is an everyday tool I use for other things as well. - aruba5erExploreri think every hole in every hinge let loose one time or another. I used toothpicks and gorilla glue. Let dry overnight and then put the screws back in. too soon and you will never remove them.The stiles on the cabinets are not wood but that dern glueboard (sawdust and glue)
- DuckExplorerI have the same hinges that use the plastic inserts in the hole. I have had to fix five of them. I took the door off and used gorilla glue per their instructions. I then used clamps to hold the hinge tight in place while it dried.
Don - jjjExplorerI also use the round tooth picks trick. I repaired my loose awning brackets with the tooth picks. Still holding tight.
- fly-swatterExplorerI have also used the toothpick trick before with good results.
- AUwing2ExplorerRound wood tooth picks cut to the depth of the hole and a little wood glue are in my general repair kit. They've all held
- nineoaks2004Exploreran old carpenter trick is to put a (you can whittle one down to size) wooden plug into the hole then the screw will catch. I usually put a dab of white carpenters glue on the plug and let it set for awhile before putting the screw back in, another idea is to use a longer screw...
- filrupmarkExplorerIf yours has the same hinges as mine you can tighten the screw to swell the plastic barrel after inserting it back into the overhead door. I did add gorilla glue to a couple also.
About Fifth Wheel Group
