Old-Biscuit
Jun 26, 2015Explorer III
Cable operated valve.......you push and cable bends vs pushing valve stem in.
Unless cable has a straight, taunt run to valve or is 'fixed'/held in position the cable can flex when wire inside binds even in the slightest
Spraying lubricant down inside cable helps....if you can get it to flow by spraying while moving wire back/forth.
Dry graphite is good lubricant.
I have found that once they start flexing......time to replace with new.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
