B_O__Plenty
Jun 27, 2015Explorer II
HappyKayakers wrote:$50.00 for a new cable! Outrageous the way they try to fleece you on this stuff. I'll give you solution a try. Thank you.B.O. Plenty wrote:
Thanks for all the replies. Found the problem. The cable housing has pulled out from the barrel located at the top of the cable right behind where it goes through the wall. When I pulled on the cable it slid into place and worked. When I pushed on it the whole outer housing moved away. If I can't re-crimp it back into place,(like that's likely to happen) it's new cable time. I priced one onlne they're sure proud of those things...
B.O.
This sounds like the same problem I had a few years ago. Someone on another forum had a DIY fix for it. Get about a 3" length of 1/4" all thread and a couple of small hose clamps. Position the all thread next to the outer housing and the cable, like a splint. Tighten clamps and test. Good luck.
B.O.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
