B_O__PlentyExplorer IIJun 26, 2015Cable pulls out but won't push inDealing with a gray tank valve that's stuck open. I opened the Cloroplast and found the valve. I can push the valve closed by hand. The wire inner cable is tight and moves with the valve and the handl...Show More
AllworthExplorer IIJun 27, 2015You may be able to use a lawn mower throttle cable. A heavy duty one from a commercial mower repair shop, not a big-box special.
Related ContentMistakenly pulled breakaway cableIs MB GLE450 sufficient for pulling Bullett Crossfire 2220MLRV cablequestion on cable pull tank valve drainsAntenna cable .
