golf_bears
Jun 27, 2015Explorer
I had the same problem. Valve closes by hand, the cable works to open the valve but the cable will not close the valve.
My problem and I suspect yours, is that the cable housing has pulled apart (unraveled) from where it connects to the fire wall mounting close to the handle. So every time you push on the handle the cable and housing both move. Just buy a new cable and replace the old one. Solved my problem.
Here check out what Amazon has.
Waste Valve Cables.
Waste Valve Cables.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
