mguay's avatar
mguay
Calling ALL Trailer Saver Owners
I recently purchased a TS3. Is everyone running their air pressure to the white line or have you fine tuned it to a set pressure?
  • I have a TSLB. Everything is about right with the line at +1 inch. I think the line is intended as a starting reference point. You are expected to tweak as necessary for your particular setup.
    When you think about all the potential hitch mount, weight and pin box combinations how could they possibly draw a line in a place that would work for everybody.
  • To the line ,and deflate before pulling out (or it will make big noise).With the binkley head I added two springs to keep it tilted down and alined to pin.
  • Howdy!
    We have a TS3 Trailer Saver on our MDT and I air it up to just above the white line. Also have a inside the cab air pressure guage and air switch which controls airing it up and deflating the hitch. Always make sure you completely let all air out of the hitch before pulling out from under the 5er. If you do not the hitch will slam upwards from the air pressure.
    "Happy Trails"
    Chiefneon
