Old_Sailor63
Sep 16, 2013Explorer
Cameo slide problem
Own a 2008 Carriage Cameo 34CK3. Replaced entertainment slide
48 tooth gear in motor side last year and having same problem again.
Gear assembly is by RBW. Replaced both the 48 tooth
gear on the shaft and the larger gear that it works with 13 months ago.
Tech not sure what is causing the 48 tooth gear to shear a
couple of teeth making the slide jump and come in a little
crooked. Know I see a lot of old/new posts regarding troubles
with various Cameo models and slides. Does anyone know
the cause?
Any suggestions would be appreciated. Thanks
the cause?
