RangerReadyExplorerMay 16, 2022Cameo Slides - Gear skippingI have a 2008 Carriage Cameo F35KS3. On the main (non-kitchen) slide the motor starts to skip once a bit of resistance comes into play. It happens on both extend and retract. The motor shaft gear does...Show More
jsr21ExplorerMay 16, 2022You can remove the motor and reem out the bolt hole a little to achieve a better mesh.
Related ContentCameo by CarriageCameo Slides - Gear skippingCameo slide outslide out issue on CameoAdding power outlets in slide with no wiring
