jsr21
May 16, 2022Explorer
RangerReady wrote:jsr21 wrote:
You can remove the motor and reem out the bolt hole a little to achieve a better mesh.
Thanks for response. Which bolt hole? You mean reem out all the motor mount holes so it has some room to move? I feel like the torque of the motor on the slides will be too much to be held by tightness of the screws. It will just shift back down.
I'm going to post some pictures in my post of the gears...does the motor gear need replacing?
My buddy is a master tech...several Carriage's had this fix.
About Fifth Wheel Group
