handsome51
May 16, 2022Explorer
That skipping is going to ruin the gear on the main track sooner or later. I had to replace my motor because one of the 1/4 20tpi holes got stripped. You could see the wear on the gear. It is on a 2006 Carriage and the original motor and gear. It had lasted 14 years. I put a new gear on the new motor. And you could see the big difference on the way it messed with the main gear track. You don't want to ream any of the holes out. Like you said their is plenty of torgue on the motor and it would move. On the bad hole on the old motor I had it helicoiled so now I have a spare.
Another thing is after each trip I always check the motor bolts on the big slides to make sure they are still tight. Use blue locktite on the threads of the three 1/4 20tpi bolts.
About Fifth Wheel Group
