laknox
Mar 16, 2015Nomad
Durango1500 wrote:
Thanks laknox. After looking my springs are already on top of the axles. So no flip needed correct?
Yes. If you have more holes in the spring hangars, that's a first step. You can add a Correct Track alignment system to gain about 2". I've seen others add heavier, longer spring shackles with cross-braces for a shorter lift. Beyond that, and you're looking at a sub-frame between the main frame and the spring shackles.
Lyle
About Fifth Wheel Group
