MitchF150
Jun 10, 2020Nomad
Blue and Red are the low point drains to drain 'most' of the water out of the lines in the rig.
The actual fresh water tank drain should be near where the fill spout is?
But, if you don't have an outside fill spout (I guess more and more are doing the 'valve' thing where you plug into the city water and then flip a switch or valve to send water to the fresh water tank).
But, the tank should still be located more to the front of the rig in front of the axles.. Might just be a very small valve, but should be visible past the covered under carriage?
Just my guess at it.
Good luck! Mitch
Good luck! Mitch
About Fifth Wheel Group
