JIMNLIN
Dec 01, 2016Explorer III
Dexter may offer a 12" brake but that doesn't mean all 12" brakes have same performance such as a 5200 lb axle vs a 6000 lb axle. According to Dexter 1-800 tech folks the 6k axle brakes have stronger brake magnets and have a higher performance brake lining.
The only way your going to know for sure is talk with Dexter tech folks. They can tell you what they need to know.
Dexter email;
Your online website says; "The Gross Axle Weight Rating (GAWR) of your running gear is determined by the lowest rated component in the assembly. The capacity of the wheel, tire, axle, brake, springs/rubber and hub are all considered." However the 5.2k/6k and 7k axles show 12" x 2" brakes. What is the determining brake spec differences in those three axle ratings ? I've looked at Dexters online brake part specs and see different part numbers but that doesn't say the 6k axle brakes have more braking performance than the 5.2k axle brakes. Thanks....xxx
Mr. xxx,
While the 5.2, 6 & 7K brakes are all 12x2 in size they do have different lining material, magnets and reinforcement of the metal backing plates. Thanks ......Jim Miller / Dexter Axle
Dexter email;
Mr. xxx,
About Fifth Wheel Group
