TxGearhead wrote:
I would get the part # for the seals and bearings from your axle manufacturer. When you take your old seals and bearings to the local auto parts store they will substitute the OEM parts for whatever they have on the shelf. I just did it 2 months ago and told myself this is the last time. I got my Dexter seal # and Timken bearing numbers. Next time it will be OEM or better quality ordered from Amazon.
Go get a bearing and seal installation tool kit, from Harbor Freight. Put the bearing races in the freezer overnight and they will go in easier. Packing a bearing is easier than falling off a log. And, get you about 6 inches of 1/2" brass bar stock to hammer the old races out. Clean any brass shards out of the hub cavity well. Buy an extra seal in case you bugger one up installing. I like to put a fair amount (tablespoon?) of grease between the seal and the inboard bearing. Hit the seal area with some sandpaper to clean any burrs off. Don't get too carried away with it though.
Most important is clean clean clean. Your hands, the bearings, the spindle, etc.
You've seen those knuckles draggers at the RV shop getting paid to pack bearings. You can do it.
I agree I like the Dexter seals, and also get them from Amazon, same with bearings, but this last time it was just repack, and new seals.
I have changed plenty of races with the brass bar. I suppose a seal installation tool kit is nice ,although I have no idea what it is :) Never had an issue reinstalling grease seals. The one thing I don't do is pack the bearings by hand anymore, I use one of those bearing packers. IMO they do a better job, and a lot less messy, and quicker. Have done many with it, without issue. I know some are old school, but at 71, I guess I'm new school now, I packed bearings way too long by hand .
But as you said keep things clean. Also will take a look at that tool kit from Harbor Freight .
