dturne69's avatar
dturne69
Can I????
I have a question. I'm looking at purchasing a 12k dry weight 15k loaded weight 5th wheel camper. The guy at camping world says it would be no problem towing it with my 2008 gmc 2500 4x4 4door. It has the duramax and Allison package. I downloaded a calculator that tells me how much my truck can safely haul. Here are the details.
Gvwr 9200
Max combined weight 22k
Curb weight 5850
Max 5th wheel pin weight over 5k
The website calculator says something about a 20 percent pin weight. I know what it is I just don't know how to come up with the figure. If I figure it right and I move the average down to 18 I could pull the coach loaded comfortably. In parentheses it says that use 25 if you don't know the pin weight. I do.
5th wheel
12k dry
15k loaded
Pin weight 2580
I've read countless stories of folks that purchased coaches and when they hooked the coach up it bottomed out on the frame. I don't want that. I want to be able to safely take my family of 5 camping. Any help would be greatly appreciated. Thanks in advance.
  • If you buy a fiver in that weight class a new/bigger truck is in your future. Your truck will "pull" a trailer like that but WILL NOT safely carry it or STOP IT!
    I as well as many others have been through this and know first hand.
  • Do not calculate off of dry weight, calculate off of fully loaded, food, clothing, essentials, dishes, tools, chairs, water etc. This all quickly adds up and can push you close to the 16000 lbs which will between 3400 to 4000 lb pin, too much for the 2500.
    I pull a 16400 lb fiver with my '08 Duramax DRW and added StableLoads to smooth out the ride and steady the truck going over road undulations. My 3500 only squats 3" with the load, now 1" with StableLoads, and pulls the trailer effortlessly.
    I would look at a lighter fifth wheel if it were me.
    Good luck and happy camping.
